Previous Topic: Contact CA TechnologiesNext Topic: Introduction
New Messages
The following messages have been added for this release:
0050E: xxxxxxxx NOT NOTIFIED—XCOM IS NOT APF AUTHORIZED
0051E: XCF FACILITY NOT STARTED—XCOM IS NOT APF AUTHORIZED
0052E: APF AUTHORIZATION REQUIRED FOR SECURITY—XCOM TERMINATING
0055E: APF AUTHORIZATION IS REQUIRED TO TRANSFER USS FILES OR USE SECURITY=SAF
0504E: SNA TRANSFERS DISABLED DUE TO CONFIG OPTION SNA=NO
0653E: NO NETWORK SUPPORT SELECTED - EITHER SNA OR TCPIP MUST BE ENABLED
0682E: SERVER TERMINATING DUE TO INVALID XCOMHIST DATA SET AND 'HISTORY=VSAMREQ'
0684W: COMPRESS=xxxxxxxx NOT PERMITTED DUE TO COMPRESS_ALLOWED PARAMETER SETTING
0685I: CHANGING COMPRESSION METHOD FROM COMPRESS=xxxxxxxx TO COMPRESS=yyyyyyyy
0686I: ---------------- wwwwwwwww, dd mmm yyyy ----------------
0689E: COMPNEG VALUE IS NOT A PERMITTED COMPRESSION ALGORITHM (COMPRESS_ALLOWED)
0933E: xxxxxx TRANSFERS ARE CURRENTLY DISABLED ON SERVER yyyyyyyy
1004E: MUST RUN AUTHORIZED TO USE XCF SERVICES
1107I: CONNECTING TO PLEXQ GROUP xxxxxxxx WHICH IS RUNNING WITH MIXED LEVEL SERVERS
1108W: NEWER XCOM FEATURES ARE NOT SUPPORTED ON THIS PLEXQ SERVER
1109W: NEWER XCOM FEATURES MAY NOT BE ACKNOWLEDGED BY THE PLEXQ SERVER PROCESSING THIS REQUEST
1125E: COMMAND REJECTED – NOT CONNECTED TO PLEXQ xxxxxxxx
1140E: xxxxx PROTOCOL SELECTED BUT xxxxxxxx IS NOT SPECIFIED – JOB TERMINATED
1185E: MAXIMUM PLEXQ CONNECTIONS ALREADY ACTIVE
1186E: ALREADY CONNECTED TO PLEXQ GROUP xxxxxxxx
1187E: NO ACTIVE CONNECTION WITH PLEXQ GROUP xxxxxxxx
1188I: CURRENT PLEXQ CONNECTIONS
1189E: xxxxxxxx INVALID PLEXQ SUBCOMMAND
1190E: xxxxxxxx PLEXQ GROUP NAME IS NOT VALID
1191E: PLEXQ GROUP NAME REQUIRED BUT NOT PROVIDED
1192E: GETMAIN FAILED FOR PLEXQ QUERY BUFFER
1403E: xxxxxxxxxxxxxxxxxxx – UNBALANCED PARENTHESES OR MISSING DELIMITER
1420W: XCOMCNTL DD STATEMENT MISSING FROM JCL
1430I: FREED HLI@DATA @ XXXXXXXX, LENGTH=X
1431I: ALLOC HLI@DATA @ XXXXXXXX, LENGTH=X
1432I: Attempted PUT of invalid RRDS record from module xxxxxxxx at offset +xxxxxxxx
1433I: SCAN FOR WAITING NSA'S FOR CONNECTION xxxxxxxx
1434I: XCOMCFEV - POSTING NSA=xxxxxxxx FOR DISCONNECTED WORKER xxxxxxxx
1435I: Duplicate attempt to WAIT on SUBTMECB
1450I: CA XCOM Data Transport for z/OS Initialization [Started | Ended]
1451E: Action Parameter Missing or Invalid
1452E: CONFIGDSN Parameter Missing or Invalid
1453I: CONFIGDSN Deleted Successfully
1454E: Symbol Call (xxxxxxxxxxxx) Failed RC=nnnnnnnn RS=nnnnnnnn
1455I: CONFIGDSN Set: xxxxxxxx
1456I: xxxxxxxx
1460I: Symbol CONFIGDSN=xxxxxxxx
1461I: Searching xxxxxxxx for TYPE=CONFIG member yyyyyyyy
1462E: Error Allocating CONFIGDSN RC=xxxxxxxx Error=yyyyyyyy
1463I: Skipping CONFIGDSN due to Allocation Error
1464I: STCPROTOCOL set to xxxxx based on EXEC PARM xxxxxxxx
1510E:System SSL Function XXXX: RC = ZZZ: Reason = YYYY
1511E: System SSL XCOM_CONFIG_SSL read error. Section: <PARAMETER>
Parameter: <INITIATE_SIDE/RECEIVE_SIDE> not found in the config file.
1512E: System SSL XCOM_CONFIG_SSL error. One or more verify criteria were not met.
1513W: System SSL CERT warning. Using sample certificates, for testing only!
1514E: z/OS 1.13 or above is required for System SSL support
8021E: BACKWARD MIGRATION OF A REQUEST QUEUE TO 11.5 IS NOT SUPPORTED
