Specifies whether CA XCOM Data Transport is to allow the mounting of a tape or DASD volume when processing the dynamic allocation of a data set.
Specifies that CA XCOM Data Transport will request the mounting of a tape or DASD volume if it is not mounted when the file is being allocated.
Specifies that CA XCOM Data Transport will not request the mounting of a tape or DASD volume if it is not mounted when the file is being allocated. The transfer will be terminated.
Default: NO
Note: The DYNALMNT default parameter can be specified in the XCOMDFLT table or overridden on the XCOMJOB/XCOMXFER EXEC parameter. The value of DYNALMNT can also be modified using the operator DFLT command.
