Previous Topic: Code the CICS Notification TransactionNext Topic: Security Interfaces
DCB ABEND Exit Software
CA XCOM Data Transport does not support, nor is it compatible with any product that modifies the DCB abend exit as this can cause unpredictable results. In many cases, this software appears to function successfully with XCOM until there is a problem. At that point, abends and errors can appear since XCOM is not able to regain control from the DCB abend exit software to handle the problem.
