Previous Topic: Assemble and Link Edit the JES2-Dependent ModuleNext Topic: Configure for LSR Support (Optional)
JES2 Installations
The CAI.CBXGSAMP member XCOMJ001 contains JES2 macros. You need to assemble and link edit it for your installation. The JCL for this task is provided in the CBXGJCL member ASM#TBLS.
To assemble and link edit the CAI.CBXGSAMP member XCOMJ001
  1. Uncomment the DD statement in the SYSLIB concatenation that refers to data set SYS1.AHASMAC and ensure that it points to the data set where the JES2 macros reside at your installation.
  2. Uncomment the EXEC statement that refers to XCOMJ001.
  3. Execute the JOB to assemble and link edit the XCOMJ001 module.
  4. Make sure you assemble XCOMJ001 on the same z/OS release as the system on which it will be used.
The use of this module is strictly optional. If it is not installed, CA XCOM Data Transport will obtain information about SYSOUT data sets only from the JES2 Process SYSOUT interface. In general, more accurate and detailed information can be obtained directly from JES2, as illustrated by this module.
This module is required if you are using PSO and need more spool attributes for reports than are gathered by default.
