Any user exit parameters in the Default Options set to YES or the name of a user exit module, assemble and link them before any of their exits can be used. The assembly JCL is provided in the library CAI.CBXGJCL(ASM#TBLS). For a description of the user exits in this library, see the appendix User Exits in the CA XCOM Data Transport for z/OS User Guide.
Note: In the assembly step, specify CAI.CBXGMAC as the SYSLIB. Also, make sure the correct SYSIN, SYSPUNCH, and SYSLMOD libraries are specified in ASM#TBLS. To simplify future product updates and to preserve the original versions of sample modules, we recommend that load modules generated for product tables and user exits be placed in a private library, rather than in the SMP/E controlled CA XCOM Data Transport target libraries.
