Select the CA XCOM Data Transport's CA Top Secret interface by specifying SECURITY=TOPS in the CA XCOM Data Transport Default Options, or specify TOPS by overriding the SECURITY parameter on the CA XCOM Data Transport EXEC statement of the started task JCL.
It is not necessary to assemble or link edit the XCOMTOPS security interface module unless it has been customized. In most cases, it is not necessary to customize the interface module.
CAI.CBXGSAMP(XCOMTOPS) contains the source code for the CA Top Secret interface. CAI.CBXGJCL(ASMTOPSU) contains sample JCL that can be used to assemble and link edit it. After customizing ASMTOPSU, edit ASMTOPSU to fit your particular installation. Next, submit the edited procedure as a job. Be sure to check for any unresolved references in the linkage editor output.
