Configuration Parameters › Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs › TCPSESS
TCPSESS
Specifies the maximum number of TCP/IP file transfers that the server can perform concurrently to any one IP address.
- 0
Indicates that no maximum limit has been set.
- 1 to 128
Specifies the maximum number of concurrent transfers the server can perform to any one IP address.
Default: 15
Notes:
This parameter should be specified to throttle TCP/IP file transfers.
- This parameter is for TYPE=SCHEDULE transfers only.
- The value specified for this parameter should be less than the value specified in the Default Options Table. If the specified value is greater than the value specified in the Default Options Table or is not specified, the value defaults to the TCPSESS value specified in the Default Options Table. The MODIFY command LIST will list this value as maximum=nnn. If there is an asterisk appended onto this LIST item, the value for TCPSESS was taken from the Default Options Table.
