Configuration Parameters › CONFIG Member Parameters › TCPSESS
TCPSESS
Specifies the maximum number of TCP/IP file transfers that the server can perform concurrently to any one IP address.
- 0
Indicates that no maximum limit has been set.
- 1 to 128
Specifies the maximum number of concurrent transfers the server can perform to any one IP address.
Default: 15
Note:
- This parameter should be specified to throttle TCP/IP file transfers. This parameter governs locally-initiated transfers only.
- For information about OMVS, see the CA XCOM Data Transport Installation Guide: OMVS Requirements and the CA XCOM Data Transport Best Practices Guide: OMVS Consideration.
