Previous Topic: QSTARTNext Topic: RECVRID
RCALPROC
Specifies the name of an external procedure that will be used for the recall of archived data sets.
xxxxxxxx
Specifies the one- to eight-character name of the recall procedure.
Default: None
Notes:
Example
If RCALPROC=XCOMRCAL is defined, then the XCOMRCAL procedure should be coded as follows to recall the data set:
//XCOMRCAL PROC XDSN=
//BR14    EXEC  PGM=IEFBR14
//RCALDS   DD  DISP=SHR,DSN=&XDSN
//         PEND
The parameter XDSN will be set to the name of the archived data set.
