Previous Topic: USEROVRNext Topic: VERL
USERPRO
Specifies whether user IDs are propagated.
YES
Specifies that CA XCOM Data Transport is to forego verification of the user ID on the remote system, because it was already verified on the local system.
NO
Specifies that CA XCOM Data Transport is to verify the user ID on the remote system even if it was already verified on the local system.
Default: NO
Note: USERPRO is relevant when the server you are using resides on a different z/OS system. In this case, if USERPRO=NO, LUSER and LPASS will be required in the SYSIN01 stream. If USERPRO=YES, LUSER and LPASS are optional. If USERPRO=YES and no LUSER is specified, the user ID for the TYPE=SCHEDULE job (or the TSO user ID if in ISPF) will be propagated to the server that is to initiate the transfer.
