Configuration Parameters › Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs › SETUP
SETUP
Specifies whether CA XCOM Data Transport should pass the SYSOUT print and class values from the JES queue to the remote system.
- YES
Indicates that either the JCL parameter values specified by the user or the JES‑assigned default values are passed.
For information about coding SETUP=YES with a VAX system, see the Notes section that follows.
- NO
Indicates that print class and form values of binary zeroes (nulls) are passed to the remote system.
For information about coding SETUP=NO with a VAX system, see the Notes section that follows.
Default: YES
Notes:
- The SETUP parameter is referenced only for transfers that use the Process SYSOUT interface.
- Specify SETUP=YES only if you are sure that all the form names and print class values passed to the remote system are valid on the remote system.
- Specify SETUP=NO if the Process SYSOUT interface is being used to communicate with a VAX system. VAX systems require every form name used to be predefined; invalid form names will cause the print job to ABEND. In a case where the VAX site does require special forms, specify SETUP=YES, ensuring that all the z/OS form names and print classes have been predefined to the partner VAX.
