Configuration Parameters › CONFIG Member Parameters › OPERLIM
OPERLIM
Specifies the maximum number of transfer requests to be displayed on the TSO/ISPF screen or at the remote system by the operator, or transfers to be returned by the TYPE=HISTORY request.
- 1 to 9999
Specifies the maximum number of transfer requests to be displayed.
Default: 5000
Notes:
- The number of requests displayed directly affects the processing speed in the TSO/ISPF session. To obtain more data, use selection criteria (for example, date, request, and so on) to limit the amount of data retrieved.
- If 0454I messages are displayed during XCOMPLEX Admin start up, review your ISPF inquiry needs to determine if the OPERLIM value or XCF table size should be adjusted.
- For TYPE=HISTORY requests, the SYSIN01 parameter OLIMIT can be used to override this value.
