Each CA XCOM Data Transport operator command is secured through a different security call. The following table lists the CA XCOM Data Transport operator commands, indicates their access levels, and specifies their complete resource names. Following the specification of each resource name is a brief description of any variables except applsec contained in the name. For a description of the applsec variable, see SAF Security Call in this chapter. The variables contained in the resource names are shown in italics.
Command |
Access |
Resource Names |
ACTIVATE |
UPDATE |
XCOM.applsec.ACTIVATE.destname Variable: destname specifies the name of the LU to be activated. |
ALTER |
UPDATE |
XCOM.applsec.DATE.destname.ownername XCOM.applsec.EPRTY.destname.ownername XCOM.applsec.SPRTY.destname.ownername XCOM.applsec.TIME.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
CANCEL |
UPDATE |
XCOM.applsec.CANCEL.destname.type Variables: destname specifies the name of the destination for which a session is to be cancelled. type specifies a CANCEL command option, that is, IMMED, PURGE, or SUSPEND. |
CNOS |
UPDATE |
XCOM.applsec.CNOS.membername Variables: membername specifies the name of the control library member containing the definition of the LU for which a CNOS conversation is attempted. |
DELETE |
UPDATE |
XCOM.applsec.DELETE.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
DFLT |
UPDATE |
XCOM.applsec.DFLT.parmname Variable: parmname specifies a certain parameter in the Default Options Table. For a list of valid parameters, see the chapter “Operation and Control” in the CA XCOM Data Transport for z/OS User Guide. |
DISABLE |
UPDATE |
XCOM.applsec.DISABLE.membername Variable: membername specifies the name of the control library member to be disabled. |
DISPLAY |
READ |
XCOM.applsec.DISPLAY.destname XCOM.applsec.DISPLAY.* Variable: destname specifies the name of the destination about which session information is to be displayed. The asterisk (*) indicates that information all active sessions is to be displayed. |
DUMP |
UPDATE |
XCOM.applsec.DUMP.destname Variable: destname specifies the name of the destination for which dump data is to be produced. |
DUMPXCF |
UPDATE |
XCOM.applsec.DUMPXCF Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
ENABLE |
UPDATE |
XCOM.applsec.ENABLE.membername Variables: membername specifies the name of the control library member to be enabled. |
EXIT |
READ |
XCOM.applsec.EXIT.data Variable: data specifies the eight-byte-long user data to be passed to the XCOMEX09 exit routine. |
HOLD |
UPDATE |
XCOM.applsec.HOLD.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
INFO |
READ |
XCOM.applsec.INFO |
INQ |
READ |
XCOM.applsec.INQ |
LIST |
READ |
XCOM.applsec.LIST.membername Variable: membername specifies the name of the control library member the contents of which are to be displayed. |
LOGFREE |
UPDATE |
XCOM.applsec.LOGFREE |
NOTRACE |
UPDATE |
XCOM.applsec.NOTRACE.destname Variable: destname specifies the name of the LU name or the IP name for which the trace function is to be disabled. |
NOXTRACE |
UPDATE |
XCOM.applsec.NOXTRACE Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
NSASTAT |
READ |
XCOM.applsec.NSASTAT |
PING |
READ |
XCOM.applsec.PING |
SAVE |
UPDATE |
XCOM.applsec.SAVE |
RELEASE |
UPDATE |
XCOM.applsec.RELEASE.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
RESUME |
UPDATE |
XCOM.applsec.RESUME.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
RSHOW |
READ |
XCOM.applsec.RSHOW.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
SHOW |
READ |
XCOM.applsec.SHOW.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
SNAP |
UPDATE |
XCOM.applsec.SNAP |
STAT |
READ |
XCOM.applsec.STAT Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
STOP |
CONTROL |
XCOM.applsec.STOP.type Variable: type specifies a STOP command option, that is, IMMED. |
SUSPEND |
UPDATE |
XCOM.applsec.SUSPEND.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
TERM |
UPDATE |
XCOM.applsec.TERM.destname.ownername Variables: destname specifies the name of the destination involved in the transfer. ownername specifies the user ID under whose security authorization the transfer is performed. |
TRACE |
UPDATE |
XCOM.applsec.TRACE.destname Variable: destname specifies the name of the LU or the IP name for which a trace is to be produced. |
VERSION |
READ |
XCOM.applsec.VERSION |
XRSHOW |
READ |
XCOM.applsec.XRSHOW Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
XSHOW |
READ |
XCOM.applsec.XSHOW Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
XTRACE |
UPDATE |
XCOM.applsec.XTRACE Variable: applsec specifies the value of the APPLSEC parameter in the Default Options Table. |
ZIIP |
READ UPDATE UPDATE |
XCOM.applsec.ZIIP.STATUS XCOM.applsec.ZIIP.ENABLE XCOM.applsec.ZIIP.DISABLE
For a detailed description of the CA XCOM Data Transport operator commands, see the chapter “Operation and Control” in the CA XCOM Data Transport for z/OS User Guide.
