This parameter specifies the default amount of secondary space that is allocated to new data sets in the units that the ALLOC parameter specifies.
Specifies the amount of secondary space that is allocated to new data sets. The ALLOC parameter determines the unit of allocation.
Default: 5 (blocks, cylinders, tracks, or records, depending on the value of the ALLOC parameter)
Note: Related parameters are ALLOC, AVGRECUNIT, PRI, DIR, CATALOG, UNIT, VOL, PSOUNIT, and PSOVOL.
