Previous Topic: Possible Error Conditions—CA Top SecretNext Topic: Access Restrictions
IBM RACF Security Interface
Select the CA XCOM Data Transport IBM RACF Interface by specifying SECURITY=RACF in the CA XCOM Data Transport Default Options, or specify RACF by overriding the SECURITY parameter on the CA XCOM Data Transport EXEC statement on the started task JCL.
It is not necessary to assemble or link edit the XCOMRACF security interface module unless it has been customized. In most cases, it is not necessary to customize the interface module.
CAI.CBXGSAMP(XCOMRACF) contains the source code for the RACF Interface. CAI.CBXGJCL(ASMRACFU) contains sample JCL that can be used to assemble and link edit it. After customizing XCOMRACF, edit ASMRACFU to fit your particular installation. Next, submit the edited procedure as a job. Be sure to check for any unresolved references in the linkage editor output.
