Previous Topic: Invoke Your Product Through the ISPF InterfaceNext Topic: How to Use Your Product with Other Products
Use the CA XCOM Data Transport Health Checks to Tune the CA XCOM Data Transport Regions
The IBM Health Checker for z/OS allows you to identify potential problems in your z/OS environment by checking system or product parameters and system status against recommended settings. The IBM Health Checker for z/OS is structured as a framework that includes a health check started task and various separate check routines provided by IBM or other vendors. CA XCOM Data Transport provides health checks for virtual storage usage (above and below the line) as well as task-level monitoring. When exception conditions are found, the CA XCOM Data Transport health checks provide detailed recommendations on how to correct the problem. The CA XCOM Data Transport health checks also make best practice recommendations for using CA XCOM Data Transport.
These health checks are automatically activated when the CA XCOM Data Transport region is started if the following components are configured and running on your system:
CA XCOM Data Transport provides the following health checks:
For more information about using the CA XCOM Data Transport health checks, see the appendix "CA XCOM Data Transport Health Checks." This information includes check parameters that can be configured to change default thresholds or settings used in the checks.
