CA XCOM Data Transport assigns default values for each TYPE=CONFIG member parameter. CA XCOM Data Transport takes these values for any parameter not specified or overwritten at installation time. However, in most cases, some level of customization is required to run CA XCOM Data Transport successfully.
The data set CAI.CBXGPARM (XCOMCNFG) on the distribution media provides a sample CA XCOM Data Transport TYPE=CONFIG member. For a printed sample of the dataset, see the Sample XCOMCNFG file in the appendix Sample Files in the CA XCOM Data Transport for z/OS User Guide.
You can edit the TYPE=CONFIG member to customize CA XCOM Data Transport to the requirements of your installation.
To edit the TYPE=CONFIG member
Note: The TYPE=CONFIG member parameters are described in the chapter, Configuration Parameters.
Before the changes made to the TYPE=CONFIG member take effect, stop and restart CA XCOM Data Transport.
Specify the name of the TYPE=CONFIG member using the CONFIG parameter on the EXEC card in the JCL initiating the CA XCOM Data Transport server or batch utility.
A TYPE=CONFIG member, that contains the initialization parameters and their respective value assignments that are implemented for the current CA XCOM Data Transport execution.
If you want to specify different environments for use with CA XCOM Data Transport, you can create a TYPE=CONFIG member for each environment. To enable a particular environment-specific TYPE=CONFIG member, specify its name as the value of the CONFIG parameter.
If no TYPE=CONFIG member name is assigned to the CONFIG parameter, CA XCOM Data Transport reads the default member matching the value of the DFLTAB parameter. If the DFLTAB parameter is also missing, CA XCOM Data Transport uses XCOMDFLT as the CONFIG member name for the parameter values.
The TYPE=CONFIG members can be stored in either a PDS data set specified in the XCOMCNTL DD concatenation or a PDS data set specified by the CONFIGDSN symbol.
Advantages of storing the TYPE=CONFIG members in a PDS data set specified in the XCOMCNTL DD:
Advantages of storing the TYPE=CONFIG members in a PDS data set specified in the CONFIGDSN symbol:
The CONFIGDSN symbol controls the search order CA XCOM Data Transport uses to load the TYPE=CONFIG member. The CONFIGDSN symbol is set at the system level and must be set using the CA XCOM Data Transport CAIRIM Initialization program (FXC0INIT).
The data set CAI. CBXGSAMP (FXC0RIM) on the distribution media provides sample CAIRIM initialization parameters to set or delete the CONFIGDSN symbol.
CONFIGDSN can be specified as:
Note:
When CONFIGDSN=dsname, the TYPE=CONFIG member is loaded as follows:
When CONFIGDSN=dsname(config), the TYPE=CONFIG member is loaded as follows:
When CONFIGDSN=XCOMCNTL or CONFIGDSN defaults to XCOMCNTL, the TYPE=CONFIG member is loaded as follows:
When CONFIGDSN=dsname:XCOMCNTL, the TYPE=CONFIG member is loaded as follows:
When CONFIGDSN=dsname(config):XCOMCNTL, the TYPE=CONFIG member is loaded as follows:
Note: XCOMXFER and XCOMXADM ignore the CONFIGDSN symbol and always loads the TYPE=CONFIG member from the XCOMCNTL DD concatenation.
