Configuration Parameters › Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs › GROUP
GROUP
This parameter can specify either of the following:
- One or more groups of LUs
- An alias for a single IP address
- xxxxxxxx
Specifies one of the following:
- The name of a group of LUs. The name can contain up to eight alphanumeric characters.
- An IP address or IP name
Default: None
Notes:
- The GROUP parameter allows the multi‑threading of file transfers to nodes that support multiple logical units but not parallel sessions.
- When a transfer to a group is requested, CA XCOM Data Transport attempts to initiate a session with each LU in the group until it succeeds in establishing a session with one of them. CA XCOM Data Transport will then use that LU as the partner node to send the file to the remote system.
- You can specify GROUP instead of an LU parameter in the SYSIN01 or TSO/ISPF panel when scheduling a transfer to a group of one or more LUs.
- If you specify GROUP, the GROUP name must match the name of a CA XCOM Data Transport control library member.
Example 1
The following is an example of how to use the GROUP parameter to set up an alias for an IP name or IP address.
Example 2
The following is an example of how to use the GROUP parameter with a group of LUs.
