Previous Topic: Define the System Administrator Table (Optional)Next Topic: System Administrator Table Parameters
Modify the System Administrator Table
To define the CA XCOM Data Transport System Administrator to CA XCOM Data Transport, you need to modify the System Administrator Table.
To modify the System Administrator Table
  1. Open the data set CAI.CBXGSAMP(XCOMADMT), which contains the CA XCOM Data Transport System Administrator Table.
  2. Assign each parameter an appropriate value.
    The System Administrator Table parameters are described in the next section.
  3. Assemble and link the System Administrator Table.
    The assembly JCL is provided in the library CAI.CBXGJCL(ASM#TBLS).
    Note: In the assembly step, specify CAI.CBXGMAC as the SYSLIB. Make sure that the correct SYSIN, SYSPUNCH, and SYSLMOD libraries are specified in ASM#TBLS.
