A LOGMODE entry whose name is the same as the value of the DLOGMOD parameter in the application definition table is the default LOGMODE. The default LOGMODE for CA XCOM Data Transport is XCOMMODE (see the description of the MODEENT parameter). Keep this name as your installations default LOGMODE. If you decide to use a LOGMODE entry name other than XCOMMODE, inform your partner CA XCOM Data Transport installations of the mode name you are using.
