Previous Topic: COMPNEGNext Topic: COMPRESS_ALLOWED
COMPRESS
This parameter specifies whether data compression is used for a transfer.
YES
CA XCOM Data Transport provides Run Length Encoding (RLE) only for blanks and binary zeroes.
NO
No data compression takes place.
RLE
CA XCOM Data Transport provides complete RLE for all repeating characters.
COMPACT
CA XCOM Data Transport provides complete RLE (as in RLE) plus a byte compaction scheme suitable for uppercase EBCDIC text.
COMPACTL
The COMPACTL compression parameter is the same as COMPACT. However, this value is most suitable for lowercase EBCDIC text.
LZSMALL
CA XCOM Data Transport compresses the data according to the small memory model of Lempel‑Ziv 77 compression.
LZMEDIUM
CA XCOM Data Transport compresses the data according to the medium memory model of Lempel‑Ziv 77 compression.
LZLARGE
CA XCOM Data Transport compresses the data according to the large memory model of Lempel‑Ziv 77 compression.
HUFFMAN
Greater compression than RLE but not as much as the Lempel-Ziv 77 modes.
LZRW3
A general-purpose algorithm that runs fast and gives a reasonable compression.
ZLIB(n)
Greater compression than LZRW3 but less than LZSMALL, LZMEDIUM, and LZLARGE. The n value can be 1 through 9.
Default: YES
Notes:
