Previous Topic: ENABLE and DISABLE CommandsNext Topic: The Construction of the Code Page Conversion Table
Customize Code Page Conversion Tables (Optional)
CA XCOM Data Transport has a code page conversion table feature that enables CA XCOM Data Transport to perform data translation based on the type of data (ASCII, BINARY, or EBCDIC) being received at a particular destination. When a session is established for a destination requiring translation, CA XCOM Data Transport searches an internal link list to find the requested code page conversion tables in the sending destination's definition. If the specified code page conversion tables are available, the destination acquires access to them and translation occurs for all direct data transfers. No data translation occurs for indirect file transfers. If the conversion tables are unavailable, the file transfers proceed without data translation.
Data translation occurs on the CA XCOM Data Transport server receiving the data file. Therefore, the code page conversion table and destination definition need to be defined and enabled on the receiving CA XCOM Data Transport server for data translation to occur. You must code and enable the code page conversion tables before the destination members.
For conversion to take place in SNA destination members, the member name used in XCOMCNTL must be the same as the LU=name in the destination member statement.
