Previous Topic: Secondary Send Pacing (SSNDPAC)Next Topic: Adaptive Pacing
VPACING Specifications
An application can override the VPACING specification of its session partner (SLU) if AUTH=NVPACE is coded in the APPL definition. This is equivalent to coding VPACING=0 in the LU definition of the SLU. The default is AUTH=VPACE.
If you do not have control over which LU is the PLU or SLU in an APPL‑to‑APPL session, then code the values as follows:
This yields the desired pacing values and maintain uniformity regardless of which APPL is the PLU.
