Previous Topic: SYSNAMENext Topic: TCPIPV6
TCPIP
Specifies if TCP/IPv4 support is enabled for transfers.
NO
TCP/IPv4 support is not enabled.
YES
TCP/IPv4 support is enabled (the TCP/IP option must be installed).
Default: YES
Note: The TCPIP parameter (as well as all related TCPIP parameters such as TCPSTACK) is ignored in the XCOMPLEX Admin Server region since this region only routes schedule transfer requests to the appropriate XCOMPLEX Worker Servers and does not do the actual transfers. TCPIP is not supported or needed by the XCOMPLEX Admin Server.
