Configuration Parameters › Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs › ACCSEC
ACCSEC
Indicates the status of the access security subfield in the ATTACH FMH‑5.
- YES
Indicates that the partner system's LU 6.2 implementation supports or requires an access security subfield in the ATTACH FMH‑5.
- NO
ACCSEC=NO indicates that the partner system's LU 6.2 implementation does not support or require an access security subfield.
Default: NO
Notes:
- This parameter applies only to partner systems such as AS/400, whose LU 6.2 implementation supports or requires an access security subfield in the ATTACH FMH‑5.
- If ACCSEC=YES is coded, the PASSWORD and USERID parameters must be specified in the TSO/ISPF panel or the SYSIN01 statement stream when a transfer is requested. The password will be decrypted before it is put into the FMH‑5.
