Previous Topic: ACBs in an XCOMPLEX EnvironmentNext Topic: Define the Logon Mode Table Entries (Optional)
Use the Sample Table to Define Your Product at Your Installation
If you want to modify the sample application definition table that is supplied on the distribution tape, note in particular the following points:
Important! Do not specify APPC=YES in the APPL definition statement. CA XCOM Data Transport implements a record‑level LU 6.2 API based on VTAM macros.
