All CA XCOM Data Transport installations using CA ACF2 Security as their security interface must reassemble the CA ACF2 Security module of CA XCOM Data Transport.
Select the CA XCOM Data Transport CA ACF2 interface by specifying SECURITY=ACF2 in the CA XCOM Data Transport Default Options, or the SECURITY parameter keyword in the started task's CA XCOM Data Transport EXEC statement PARM field of the started task. For more information, see the chapter “Configuring and Customizing Your Product”.
Member ASMACF2U in CAI.CBXGJCL provides an example of assembling and linking this CA ACF2 Security module. For more information, see the appendix "Sample Files" in the CA XCOM Data Transport for z/OS User Guide.
If you have an existing XCOMACF2 module that is assembled and working for the current release of CA XCOM, and you have upgraded to a newer release of CA ACF2, you can just relink the module. The CAI.CBXGJCL library contains a sample JCL procedure that can be used to link CA XCOM Data Transport CA ACF2 interface module to the version of CA ACF2 that is running. Edit CAI.CBXGJCL (LINKACF2) to suit your particular installation. Next, submit the edited procedure as a job. Be sure to check for any unresolved references in the linkage editor output.
