Previous Topic: ALLOCNext Topic: APPLSEC
ALIAS_FAIL
Causes CA XCOM to set RC to 0 if set to a value of NO or 16 if set to a value of YES when a bad ALIAS is found during a TYPE=EXECUTE XCOMJOB transfer of a PDS load library.
The possible values are:
NO
The default value and causes CA XCOM to set RC to 0 as it did in prior releases.
YES
This value causes CA XCOM to set the RC to 16 which means a logic error has occurred so that the user is alerted that a bad ALIAS has been detected.
Action
Remove the invalid alias from the data set.
Default
NO
