Previous Topic: DEFAULT_CONVERRORNext Topic: DEFAULT_INPUTERROR
DEFAULT_DELIM
This parameter specifies an optional encoding for which the specified DEFAULT_CHARSET is based. If specified, encoding must be EBCDIC and the first option in the list.
Additionally it specifies a list of delimiters to use for USS-based output files when FILEDATA=TEXT.
Used only for UNICODE transfers (CODE=UTF8 or CODE=UTF16).
Valid options:
EBCDIC – The specified character-set is EBCDIC encoded.
NA – Not applicable, the system default delimiter is used.
NL – New line
CR – Carriage return
LF – Line feed
CRLF – Carriage return/Line feed
LFCR – Line feed/Carriage return
CRNL – Carriage return/New line
Default: EBCDIC:NA
Notes:
