Previous Topic: DEALLOCMSGNext Topic: DEFAULT_CONVERROR
DEFAULT_CHARSET
This parameter specifies the default character set CA XCOM Data Transport uses for Unicode transfers (CODE=UTF8 or CODE=UTF16).
CCSID#nnnnn/tttttttt
nnnnnn - specifies the CCSID number that corresponds to the character set. Valid values are 1 - 65535.
tttttttt (optional) – specifies the technique search order IBM Unicode Services uses when performing conversion. From 1 to 8 characters are specified. Valid values to use are:
R - Roundtrip conversion
E - Enforced Subset conversion
C - Customized conversion
L - Language Environment Behavior conversion
M - Modified for special use conversion
B - Bidi transformation (Bi-directional) conversion
0-9 - User defined conversions
Default: CCSID#37 (US EBCDIC)
Notes:
