This parameter identifies the appropriate action when the input file contains data that is not consistent with the specified input character set.
Replace each piece of erroneous data with the default substitution characters defined for the Unicode character set.
Replace each piece of erroneous data with the Unicode character that the decimal value nnnnnnn identifies. This option is not supported for z/OS systems, where the replacement character is defined in the conversion table that is defined to IBM Unicode Services. This option is treated as REPLACE. The replacement character has a valid range of 1 – 1114111.
The erroneous data is disregarded, but a warning message is issued at the end of the transfer. The message identifies that this condition occurred and provides a total count of the number of ignored bytes. This option is not supported for z/OS systems and is treated as REPLACE.
The transfer terminates with an error condition.
Default: The DEFAULT_INPUTERROR parameter in the destination member or CA XCOM Data Transport Default Options Table specifies the default.
