Previous Topic: DEFAULT_CHARSETNext Topic: DEFAULT_DELIM
DEFAULT_CONVERROR
This parameter identifies the action when the input file contains characters that cannot be converted. The characters are not included within the output character sets character repertoire.
REPLACE
Replace each unconvertible character with the default substitution characters defined for the Unicode character set.
REPLACE#nnnnnnn
Replace each unconvertible character with the Unicode character that the decimal value nnnnnnn identifies. If the specified replacement character cannot be represented in the output character set, then the transfer is failed. This option is not supported for z/OS systems, where the replacement character is defined in the conversion table that is defined to IBM Unicode Services. This option is treated as REPLACE. The replacement character has a valid range of 1 – 1114111.
SKIP
The erroneous data is disregarded, but a warning message is issued at the end of the transfer. The message identifies that this condition occurred and provides a total count of the number of skipped characters. This option is not supported for z/OS systems and is treated as REPLACE.
FAIL
The transfer terminates with an error condition.
Default: The DEFAULT_CONVERROR parameter in the destination member or CA XCOM Data Transport Default Options Table specifies the default.
