Previous Topic: XCOMPLEXNext Topic: Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs
ZIIP
Specifies whether CA XCOM Data Transport should utilize zIIP processors to reduce CPU utilization costs.
Specify Yes or No to indicate if a zIIP can be utilized to offload some processing from the main CPUs.
Default: YES
Note: ZIIP can only be specified in a TYPE=CONFIG member. If the XCOM Default Option Table is used, the default value will be used.
