Specifies the multiplier for Primary and Secondary allocation units when allocating based on the number of records.
Indicates that the PRI and SEC parameters specify the number of records to allocate for.
Indicates that PRI and the SEC parameters specify the number of records in thousands (so it would be the number specified multiplied by 1024).
For example, specifying 3 would be stating 3K or 3072 records.
Indicates that PRI and the SEC parameters specify the number of records in millions (so it would be the number specified multiplied by 1048576).
For example, specifying 2 would be stating 2M or 2097152 records.
Default: U
Note: This parameter applies only when the alloc value in the SPACE parameter specifies a value of REC indicating that a file is being allocated based on a specific number of records.
