Optional.
Specifies the name of the Default Options Table to be converted for use as a TYPE=CONFIG member and be used as the source for configurable options for this invocation of XCOMJOB. If a CONFIG Member already exists with this same, it will be used instead, and no conversion will take place. If both the DFLTAB and CONFIG parameters are specified, the CONFIG parameter takes precedence.
Default: XCOMDFLT
Optional.
Specifies the name of the CONFIG Member to be used as the source for configurable options for this invocation of XCOMJOB. If both the DFLTAB and CONFIG parameters are specified, the CONFIG parameter takes precedence.
Default: XCOMCNFG
