Previous Topic: Manage UsersNext Topic: Add Users
Display Users
You can use the Manage Users page to display configured users of CA XCOM Gateway.
  1. Log in to CA XCOM Gateway.
    The Overview page appears.
  2. Click Administration.
    The Administration page appears.
  3. Click Manage Users.
    The Manage Users page appears.
    Display Users
  4. Click the downward arrow and select the desired columns.
    Column resize can be done by dragging the column borders with the mouse.
    Sorting can be done by clicking the arrow icon located at the right corner of each column and then selecting either Sort Ascending or Sort Descending.
Filter Users
You can use the Manage User page to display and filter specific users for the CA XCOM Gateway.
To display filtered users.
  1. Click the Filter icon on the right-hand side of the title bar.
    The Filter Users panel appears.
  2. Select the Policy name from the drop-down or type the User name in the User Name field.
  3. Click Apply to view the specified users.
    In the Display Users table, only the filtered Users appear.
  4. Click Remove Filter to clear the applied filter.
    All Users are listed in the display users table.
  5. Click the Hide Filter Icon, the user filter panel disappears.
    The Show User Filter button is a toggle button, upon selection it changes to the Hide Filter button.
