After selecting a policy subdirectory on the server, you can upload a file from your computer to the CA XCOM Gateway and within the product, that file is automatically assigned to the selected policy.
Note:
Example:
If there are two instances of the file Test1.txt, they appear in the display list as Test1-20110103111523.txt and Test1-20110102100515.txt, indicating that the first instance was created on January 3, 2011 at 11:15:23 and the second on January 2, 2011 at 10:05:15.
For SFTP command-line utility
put filename
Your computer looks for the specified file in the current directory in which you have launched the SFTP program.
mput filenames
If you have multiple files to upload, then use this command.
mput test*.txt
All the files that starts with text ‘test’ and has the extension ‘.txt’ will be uploaded or copied in the remote directory in CA XCOM Gateway from the directory in which you have launched the SFTP program.
Note: On Windows, the command prompt window opens in one of the following directories:
For windows perform one of the following action:
Note: There are some unsupported commands on the product file system. It is necessary that the supported commands do not use the unsupported commands internally.
For Example:
The SFTP Client WinSCP uses the chmod own path (unsupported) command internally while uploading a file to gateway server. You must select the Ignore permissions error to upload without any errors.
For an SFTP client program
Do one of the following:
Copyright © 2014 CA.
