Previous Topic: Setting Up CA GMINext Topic: Install and Configure CA GMI
CA GMI Components
CA GMI consists of the following two components:
z/OS Server
Installed on the mainframe.
User-Interface (PC) Clients
The following user-interface clients are available:
Windows Client
This client is a Windows-based user-interface. This client provides full functionality and when you install the Windows Client you also install the Config Client and the CA Vantage documentation set. You can use the Config Client to set CA Vantage parameters.
Web Client
This client is a web-based user interface. The client can be used from any PC with internet access to the web client application server. You can access the CA Vantage documentation set from the web client. The current web client provides partial functionality compared to the Windows client.
Note: Install the Windows client first and then the web client. The Windows client contains the Config client which you can use to set CA Vantage system parameters.
3270-based interface (View 3270 Client)
This client provides partial functionality that is limited to:
  • User-driven functionality of view and analysis
  • Filtering and sorting, zooming
  • Ability to initiate actions on selected entries
Note: The View 3270 Client is considered a character-based user-interface, not a graphic-based user-interface, so it is not discussed in this guide. For View 3270 Client installation and configuration information, see the chapter "Configuring CA GMI" in the CA Vantage Configuration Guide. For more information about using the View 3270 Client, see the chapter "Navigating the View 3270 Client" in the CA Vantage User Guide.
