IBM zIIP specialty processors are installed and available for use yet CA Vtape is not currently configured to take advantage of these specialty processors.
Investigate and evaluate the use of zIIP specialty processors for CA Vtape. The use of zIIP specialty processors by CA Vtape increase performance and lower general processor usage.
The CA Vtape use of zIIP specialty processors is controlled by the zIIPExploitation and PercentRunOnZIIP attributes defined in the respective Startup Options and Dynamic Options Sections of the CA Vtape parmlib.
To enable CA Vtape exploitation of zIIP specialty processors, specify the zIIPExploitation attribute as zIIPExploitation=Y, and set the PercentRunOnzIIP attribute to a value greater than 0.
None
Yes
Yes
For more information, see the chapters "Operational Considerations" and "The Parameter Library (PARMLIB)" in the Configuration Guide.
SVTH4501I
CA Vtape is not configured to take advantage of the IBM zIIP specialty processors available on this system.
