Previous Topic: Health ChecksNext Topic: VTAPE_CDS_SEPARATION
VTAPE_TMS_COMPATIBILITY
Description
This check monitors that the tape management system specified by the TapeManagementSystem= attribute and ensures that it can be located and if located that the TMS is at the appropriate maintenance levels. The interval for this check is once each time CA Vtape is started.
Best Practice
The tape management system you employ must be at a level that is supported and recognized by CA Vtape.
Parameters Accepted
None
Debug Support
Yes
Verbose Support
Yes
Reference
See the section Tape Management System Interface and the description of attribute TapeManagementSystem= in the section DYNAMIC OPTIONS in the Configuration Guide.
Messages
SVTH1101E
CA Vtape verification of the defined Tape Management System (TMS) failed. The TMS release level or maintenance level is not compatible with the CA Vtape TMS interface.
