Previous Topic: SET WRITPROTNext Topic: START GROUP=
SHUTDOWN
This command works just like the STOP SVTS command. It stops the CA Vtape address spaces and brings down the subsystem.
If the Backstore Engine has an active subtask with a tape drive allocated, the subtask stops gracefully and the tape drive is released prior to the SVTSAS.SVT1PT address space being shutdown. If an application job or a started task has a Virtual Device allocated, the shutdown is delayed until the application job or started task completes its use of the Virtual Device and releases it. When the Virtual Device is released, the corresponding SVTSAS.SVT1Vn address space will complete its shutdown.
During the shutdown, the Virtual Devices are automatically varied offline.
Syntax
SVTn SHUTDOWN
Note: For more information about stopping CA Vtape, see the section Starting and Stopping CA Vtape.
