Previous Topic: RESTART TIMERMGRNext Topic: SET BACKSTORE=
RESTART UNIT=
This command emulates the Power OFF/Power ON of a real tape device. It stops the activity executing in the specified Virtual Device, terminates the subtask, and restarts it. Other Virtual Devices running under the same Virtual Control Unit are not affected. The Virtual Device is not varied OFFLINE or ONLINE during this process.
You can issue this command to reset hang conditions affecting only one Virtual Device or to recover it from processing errors. This command will not eliminate a partially satisfied or unsatisfied Mount Pending condition. In this case, use the SVTn MOUNT command to redrive the virtual mount or cancel the affected job.
Syntax
SVTn Restart Unit=nnnn
Where nnnn is the address of the Virtual Device.
