Previous Topic: Processed Exception ReportNext Topic: Results for Recycled Virtual Volume Files
Processed Virtual Volume Files
Report SVTRC130.D lists the Virtual Volume Files that were processed by RECYCLE. Only volumes for the group and subgroup or subgroups specified by the RECYCLE command are listed. If multiple RECYCLE commands are coded, a report will be produced for each command.
Example of the SVTRC130.D report
RECYCLE.SVTRC130.D  CA11.SVT2                            CA VTAPE                       HH:MM:SS mm/dd/yy  PAGE#    12 CA Vtape r11.5                          VIRTUAL VOLUME FILES RECYCLED TO PRIMARY GROUP# 61                                     REPORTED IN PROCESSING ORDER          VIRTUAL DSN PHYSICAL  FILE ESTIMATED GROUP SUB VOLSER SEQ VOLSER    SEQ#  #MB.USED  PHYSICAL FILENAME ----- --- ------ --- ------  ------  --------  --------------------------------------------    61  S  101744 P   542613       1         8  QAPROD.VVE.V101744.PRIMARY    61  S  101745 P   542613       2         8  QAPROD.VVE.V101745.PRIMARY    61  S  101746 P   542613       3         8  QAPROD.VVE.V101746.PRIMARY    61  S  101747 P   542613       4         8  QAPROD.VVE.V101747.PRIMARY    61  S  101748 P   542613       5         8  QAPROD.VVE.V101748.PRIMARY    61  S  101750 P   542613       6         8  QAPROD.VVE.V101750.PRIMARY    61  S  101751 P   542613       7         8  QAPROD.VVE.V101751.PRIMARY    61  S  101752 P   542613       8         8  QAPROD.VVE.V101752.PRIMARY    61  S  101753 P   542613       9         8  QAPROD.VVE.V101753.PRIMARY    61  S  101754 P   542613      10         8  QAPROD.VVE.V101754.PRIMARY    61  S  101756 P   542613      11         8  QAPROD.VVE.V101756.PRIMARY    61  S  101758 P   542613      12         8  QAPROD.VVE.V101758.PRIMARY    61  S  101759 P   542613      13         8  QAPROD.VVE.V101759.PRIMARY    61  S  101760 P   542613      14         8  QAPROD.VVE.V101760.PRIMARY    61  S  101761 P   542613      15         8  QAPROD.VVE.V101761.PRIMARY    61  S  101602 P   542613      16         8  QAPROD.VVE.V101602.PRIMARY    61  S  101603 P   542613      17         8  QAPROD.VVE.V101603.PRIMARY    61  S  101739 P   542613      18         8  QAPROD.VVE.V101739.PRIMARY    61  S  101740 P   542613      19         8  QAPROD.VVE.V101740.PRIMARY    61  S  101741 P   542613      20         8  QAPROD.VVE.V101741.PRIMARY
   61  S  101565 P   542613      21         8  QAPROD.VVE.V101565.PRIMARY    61  S  101566 P   542613      22         8  QAPROD.VVE.V101566.PRIMARY    61  S  101568 P   542613      23         8  QAPROD.VVE.V101568.PRIMARY    61  S  101572 P   542613      24         8  QAPROD.VVE.V101572.PRIMARY    61  S  101574 P   542613      25         8  QAPROD.VVE.V101574.PRIMARY    61  S  101577 P   542613      26         8  QAPROD.VVE.V101577.PRIMARY    61  S  101579 P   542613      27         8  QAPROD.VVE.V101579.PRIMARY    61  S  101581 P   542613      28         8  QAPROD.VVE.V101581.PRIMARY    61  S  101583 P   542613      29         8  QAPROD.VVE.V101583.PRIMARY    61  S  101585 P   542613      30         8  QAPROD.VVE.V101585.PRIMARY    61  S  101587 P   542613      31         8  QAPROD.VVE.V101587.PRIMARY    61  S  101589 P   542613      32         8  QAPROD.VVE.V101589.PRIMARY    61  S  101591 P   542613      33         8  QAPROD.VVE.V101591.PRIMARY    61  S  101593 P   542613      34         8  QAPROD.VVE.V101593.PRIMARY    61  S  101595 P   542613      35         8  QAPROD.VVE.V101595.PRIMARY    61  S  101597 P   542613      36         8  QAPROD.VVE.V101597.PRIMARY    61  S  101599 P   542613      37         8  QAPROD.VVE.V101599.PRIMARY    61  S  101601 P   542613      38         8  QAPROD.VVE.V101601.PRIMARY
