Previous Topic: TCR Relationship between SOURCE and TARGETNext Topic: RECYCLE Command
REPORT Command
The REPORT command determines the level of detail produced in various printed RECYCLE reports.
Syntax
REPORT CANDIDATE(ALL|DETAIL|SUMMARY|NONE),
 SELECTED(ALL|DETAIL|SUMMARY|NONE),
 PROCESSED(ALL|DETAIL|SUMMARY|NONE)
The following gives details about each line of the syntax:
(Optional)
Default value: ALL
The CANDIDATE report displays all Virtual Volumes considered for selection. This command option lets you control the level of detail that is printed in this section of the reports.
SELECTED(ALL |DETAIL |SUMMARY |NONE)
(Optional)
Default value: ALL
The SELECTED report displays all Virtual Volumes selected by RECYCLE. The Virtual Volumes selected for processing are determined by parameters specified in other control cards. This command option allows you to control the level of detail that is printed in this section of the reports.
PROCESSED(ALL |DETAIL |SUMMARY |NONE)
(Optional)
Default value: ALL
The PROCESSED report displays all Virtual Volumes merged by RECYCLE. This command option lets you control the level of detail that is printed in this section of the reports.
