By selecting option 2 from the Main Menu, you can view information about all the Virtual Devices owned by this Subsystem and any tape devices in use by this Subsystem’s Backstore Engine.
The following panel would be displayed for a Subsystem with nine Virtual Devices (3513-3517 and 3504-3506) that is currently Externalizing to physical drive (3702):
Menu Functions Confirm Utilities Help ---------------------------------------------------------------------------- File Help ---------------------------------------------------------------------------- CA Vtape Tape Device Status Display Row 1 to 10 of 10 Command ===> Cache Limit(MB) 76149 Cache Inuse(MB) 46578 MB Freeable 1604 Scratch Pool1=161 Pool2=485 Pool3=1296 Pool4=n/a Pool5=n/a Pool6=n/a Pool7=n/a Pool8=163 The following device list contains information on virtual tape and physical devices allocated to CA-Vtape. Volume Dev# Status Devt Jobname # SIOs SEQ# Phy/Virt % n/a 3702 Mount Pd 349S SVTSAS 11 0 Physical 0 n/a 3513 349S 14 0 Virtual 0 n/a 3514 349S 4 0 Virtual 0 n/a 3515 349S 14 0 Virtual 0 n/a 3516 349S 14 0 Virtual 0 n/a 3517 349S 4 0 Virtual 0 n/a 3518 349S 14 0 Virtual 0 n/a 3504 349S 14 0 Virtual 0 n/a 3505 349S 14 0 Virtual 0 n/a 3506 349S 14 0 Virtual 0 +------------------------------------------------+-------------------------- |The cross-system information has been refreshed | +------------------------------------------------+
The information shown includes the following:
Note: For more information about Cache Limit (MB), Cache Inuse (MB), MB Freeable, and Scratch Pools, see Cache Management and Scratch Pool Header Information.
Displays the volume serial number associated with the device.
Displays the device number or unit address.
Displays the status of the device.
Displays the device type.
Displays the jobname that has the device allocated.
Displays the number of Start I/Os to the device.
Displays the file sequence number.
Displays "Virtual" for CA Vtape Virtual Devices and "Physical" for devices in use by the Backstore Engine.
For Virtual Devices always indicates zero. For devices used by the Backstore Engine, indicates how much of a Virtual Volume has been copied to the Backstore Tape.
