The stacking groups are designed to provide a vehicle that allows data sets with similar characteristics and requirements to be stacked together. These groups are predefined with various attributes and are selected by Data Set Name Filters or DFSMS Data Class Filters. These filters are controlled by the CA Vtape administrator and require minimal ongoing management when using stable naming conventions.
Each group is broken down automatically by expiration date into three subgroups to minimize fragmentation and the need to consolidate fragmented tapes. The expiration date breakdown is controlled by customizable attributes in the Group Definitions.
You can use the stacking groups to organize data by different categories. For example,:
Note: Each group and subgroup combination uses separate Backstore Tapes during the Externalization process.
Thirty-two customizable groups are available. You can modify and refresh the group settings dynamically so that any combination of primary, duplex, triplex, and export copies can be written or not written by any group.
