RECYCLE Utility › RECYCLE Features
RECYCLE Features
The RECYCLE utility has the following features:
- It merges CA Vtape Externalized Virtual Volumes onto new Backstore tapes without using the CA Vtape DASD buffer. Data is moved, tape-to-tape, keeping the physical tape reorganization fast and efficient.
- All application data remains accessible during processing.
- Threshold-based processing reduces volume reorganization requirements to a minimum and keeps system overhead low.
- Command options enable processing by selected groups to further control processing overhead.
- Command options enable processing by selected VOLSERs.
- Command options that provide cost reduction of system resources by utilizing Tape Consolidation features.
- The output Backstore tapes can optionally be duplexed.
- Any number of concurrent processes can be run, allowing you to take maximum advantage of available system resources.
- SIMULATE processing provides tools for testing and evaluating different processing threshold parameters to allow for performance tuning and optimization of the Backstore tapes.
- Reports provide extensive knowledge of all actions taken. They provide valuable feedback on how efficiently the Backstore and RECYCLE processes are functioning.
- Scheduling and duration is client-specified and can be modified at any time. You can interface with CA 1 and CA TLMS to determine the Virtual Volume's expiration date and to report upon which physical volume the Virtual Volume has been recycled to (container).
- It can be gracefully shutdown using a console command.
- Optional DD Statements can be coded to select a list of physical tape VOLSERs for input processing and to exclude a list of physical tape VOLSERs from input processing, or to do both.
Note: Because RECYCLE serializes its processing at the group level, concurrent processing of the same group is prevented by design.
