Previous Topic: DISPLAY PINNext Topic: DISPLAY P2P
DISPLAY POOLS
This command shows the run-time or active Volume Pool values. The output of the command shows all active Pools defined to CA Vtape, the number of Virtual Volumes assigned to the respective pool, the number of Virtual Scratch Volumes remaining in the pool, and the associated Virtual Volume serial numbers assigned to the pool. Virtual Volumes are displayed in consolidated ascending range order (for example, vvvvvv-vvvvvv) by pool number.
Syntax
SVTn Display POOLS
Note: By adding the SVTn Display POOLS console command to the Startup Commands section in the parmlib, the Volume Pools can be automatically documented at startup.
When the display of non-contiguous volume pool ranges exceeds 40 lines of output the Display Pool Command appends a plus sign {+} at the end of the last volume range. The plus sign (+) indicates that a complete list of volumes has not been displayed. To obtain a complete volume pool range list, submit the HLQ.CCUUJCL (GENVOLPL) member.
