Previous Topic: External LoggerNext Topic: USS Backstore
Volume Pool Definitions
Volume Pool Definitions make it possible to associate Virtual Volser ranges with specific pool names. The pool name can then be used to associate any of the defined ranges with specific data sets utilizing the Group and Filter Definitions.
Up to eight pools can be defined. Seven of the pools (POOL 1 through POOL7) are for your use and can be modified and refreshed dynamically. The eighth pool is reserved for CA Vtape use with the Peer-To-Peer option.
The Group Definitions are updated with the defined pools names. When a scratch mount is intercepted, the filter which caused the intercept assigns a group number and by association a pool name. The Volume Pool Definitions are then used to assign a scratch VOLSER from that pool to the mount.
Note: Volume Pooling is required when using control data sets that allow more than 510,800 Virtual Volumes to be defined.
Note: Multiple pool definitions are not supported under JES3. Under JES3 only one volume pool can be defined.
