This command displays internal configuration and licensing information, CA Vtape Complex Subsystems, and non-parmlib parameter settings.
SVTn Display Status
Example of information displayed by the DISPLAY STATUS command
SVT1 D S SVT1X0224I Subsystem Status Display 778 Field State ---------------------- --------------------------------- Release r12.0 Subsystem Active System id XE61,1 IDRC Default Highspeed open On CPU isolation Off DSN prefix VTAPE Recall Order Primary Console S311, CA11.SVT3 P2P VCAT Signature B50D64E9 Global Vcat Buffers #Free=1, #InUse=0, HiUsed=1 Control Data Sets Enhanced Capacity Licensed Status --Local Drives-- -Remote Drives-- Sysplex Sysname SVTS Defined Active Defined Active -------- -------- ---- ---------------- ---------------- PLEXC1 CA11 SVT1 40 3 0 0 CA31 SVT1 40 0 0 0 XAD1 SVT1 40 5 0 0 XE61 SVT1 40 2 4 1 ---------------------- ---------------- ---------------- 4 Active Subsystem(s) 160 10 4 1 Drive License(s) 160 4 SVT1X0100I Command Complete
The System ID in the display is an internal value created by CA Vtape and used to differentiate between two CA Vtape subsystems running on the same LPAR. The value is created by taking the eight-digit system name and overlaying the last two digits with a comma and the CA Vtape subsystem number and removing any blanks that precede the comma. For example, when CA Vtape subsystem SVT1 is started on a LPAR with a system name of CAIPROD, the internal system ID will be “CAIPRO,1.” If the system name is PROD, the internal system ID will be “PROD,1.”
The Console in the display is for a CA Vtape P2P remote subsystem defined in the parmlib Peer To Peer Remotes Section. All console output from this subsystem will be echoed on the console of the remote P2P subsystem. A value of Local indicates that no echoing is being performed. This value can be changed with the SET CONSOLE Console Command.
The P2P VCAT Signature is a unique 4 byte value created by CA Vtape to identify a CA Vtape Complex. It is primarily used by the CA Vtape P2P Option to identify remote systems.
Note: For additional information concerning the P2P option and the P2P VCAT Signature, see the chapter “CA Vtape Peer-To-Peer (P2P) Option” in the Configuration Guide.
